kamiledi15
- Joined
- May 21, 2013
- Messages
- 31
Yes, I will probably upload the video today, I will be home after about 8 hours. I took off the upper case, so you can see how the head behaves.
When I insert the floppy and try to open it, the head falls down on it and sometimes that's all and sometimes it makes two short moves - one forth and one back and it stops and it goes up when the light turns off. I tried to do as you suggest, to move it slightly with my finger, but I can't move it even one milimeter - but I tried it when ifalled down on the floppy, maybe I should try to do it when it's in standard position?
It's a little dirty inside, so I will try to clean it, but the head seems to be clean. I will also try all floppies that I have, because I found on another forum that someone had 95% floppies dead after 20 years of not using it. My situation is the same - the floppies weren't used for about 20 years, but were kept in good conditions, in dry and dark place, in the plastic case, so they are clean and without any dust. My 3,5" floppies are kept in the same place and all of them work. But comparing it to my 3,5" drive I'm not sure if it even tries to read the floppy.
It seems that I'm not the only one who has this kind of problem. Apart from the video which I gave you a link to in previous post, I found this on another forum:
Same model, same problem - I also have NEC FD1157C. I don't know about its condition, because I bought it few days ago and the seller said that he connected it to his PC, the light turned on and he heard the spinning sound, so he claimed that it works. But he didn't have any 5,25" floppies to check, so it didn't prove anything.One was an NEC FD1157C (Dec 1987!) which did seek to track 83 but refused to read anything, and unlike a 3.5" drive I tried earlier, behaved the same with and without a disk inserted. Luckily this is already listed on your page of supported drives, so it must be a problem with the drive. I will test it in a PC and see if it behaves any different (only found this drive two days ago in a dumpster so perhaps this is no surprise.) Slow firmware didn't help.
