kamiledi15
- Joined
- May 21, 2013
- Messages
- 31
This diskette is labelled: "Verbatim Verex MD2-HD, Double Sided, High Density, Soft-Sectored". Another one is labelled: "Verbatim DataLifePlus MD2-HD Teflon Protection Formatted for IBM PC's, AT's and other 1,2 MB systems, Double Sided - High Density". In cmd it stops at 0% and I'm getting an error: "Invalid floppy or damaged path 0 - the floppy can't be used" (free translation from polish, so it may be a little different in english). In Dos formatting goes to 100% and then it says "Unable to write boot, format terminated". I don't want to try formatting other diskettes because of the data which is stored on them - I don't want to lose it.- What type of diskette are you trying to format, and is the density actually labelled from the factory?
When I was recording the video, I just typed "format a:". After your post I tried to type "format a: /T:80 /N:15", but the result was the same.How are you trying to format them, specifically? I assume you've discovered that you can not format a 5.25 diskette from within XP, and if you use DOS or a CMD prompt you have to specify tracks and sectors:
1.2MB diskette: /T:80 /N:15
360kB diskette: /T:40 /N:9
I don't think that I will find anyone in my neighbourhood who would be able to fix it. People who are repairing computers don't want to take older technology, because they don't have parts for it. As I said, maybe I will be able to get another, this time working drive, but this guy has to check if it works. But if you have any ideas about how I could fix it by myself, feel free to tell me.if that is indeed the case then that obviously has to be repaired
Do you mean this thing? http://blogimg.goo.ne.jp/user_image/14/4f/204ce65ce76229c0a7e4d043930804f1.jpgIs the shield properly attached to the upper head? They had a habit of coming loose and falling off.
Yes, it fell off, but I attached it again with glue. I don't know if I did it correctly.
