DistantStar001
- Joined
- May 8, 2019
- Messages
- 178
So anyone who has encountered my most recent posts on this forum probably figured out that I've recently acquired a few MS-DOS based machines as of late. An XT, a Tandy 1000EX, and most recently, a Compaq Portable. Unfortunately, with the exception of the XT, most of these are dependent on Floppies for the time being. So I need to make some boot disks and I'd like them to be the disks that were actually meant for the systems. Physical disks aren't a problem. I have tons of them. But getting the .img files over to them has been.
I tried using my 486s to do it, but one is on the fritz, and the other threw a two-month-long fit when I tried to add a 360k drive to it. Seriously, it wouldn't even recognize its old drive (a 3.5/5.25 inch combo) even after I reverted everything back. I had to replace it with two separate high-density drives. And even then, it took a while to find a pair it would accept.
Obviously writing double-density disks with a high density drive is less than ideal. I mean sometimes it works. But it's never stable. Most annoying was when I had one disk that would read reliably in my Tandy, but my XT couldn't make heads nor tails of it.
So this brings me to my question: What do I need for my XT to accomplish this task? Since at the moment, it's my best candidate for the job (at least until I can figure out what's going on with either of my 486s). Still, the XT is natively 360k. I've managed to find many of the .img files I want. The CF Adapter makes file transfer a simple drag-and-drop. So, since I can get the .img files over... What do I need to put them on a physical disk?
Side note: If there is something XT compatible that can write alternative disk formats as well, let me know. I have some TRS-80s that have been starved for software as well.
