Hi,
I'm trying to test the M8655 board but I can´t make it send any character. This is my configuration:
I think the TLS instruction uses the two numbers in the middle as the transmit address of the card, but even if I change them I get nothing. I tried putting a scope in the F pin of the BERG connector but the signal never changes. I guess I must be doing something wrong because I tried 4 different boards and none of them seem to work. I'm using a PC with a serial port and hyper terminal as a dumb terminal. Any ideas?
Thanks!
Jumpers:
FIL - open
TTY - open
SWD - closed
W2 - closed (9600 baud)
W5 - open
SB - open (no stop bit)
NP - open (no parity)
EVN - open (even parity)
NB1 - open (8 bits per char)
NB2 - open
Dipswitches:
76543210
XMIT - 11100100 (9600 baud, addr 04)
RCV - 11100011 (9600 baud, addr 03)
Conections:
BERG | DB9
F | 2
J | 3
VV | 5
BERG pin E to pin M
Test program (loop that prints char "A"):
0000 7200 CLA
0001 7001 IAC
0002 7002 BSW
0003 7001 IAC
0004 6046 TLS
0005 5004 JMP 0004
Thanks!
