Chuck(G)
25k Member
I doubt that it's magnetic storage of any sort. Too bad the front view from the 2007 photos is so fuzzy--one might be able to read some of the legends on the connectors and panels.
I loaded the above pic into Paint.NET and moved the contrast and brightness scrollbars up and down, and to me it looks like DRESSER SIE Model MR-608A Serial 5787-C
SIE made seismograph units, perhaps this is close https://www.collectorsweekly.com/stories/93684-vintage-seismograph-sie-co-magnetic-rec
It seems not a storage device per se. I was wondering if the drum might be a chart recorder--apparently so. That would fit in with the very simple electronics.
So if you haul it back, what the heck are you going to do with it?
I suspect that both machines are analog drum recorders. The larger drum would be used to print a graph of the signal recorded on the multiple heads. It may have been connected to a mini or such but that may have been to digitize and analyse the recorded signal.
The SIE is most likely Seismographic Imaging Equipment. I'd guess it was used for recording multiple sensors for things like oil exploration, with tomography. The multiple heads would record each signal and then the computer would do the calculations. The larger drum would be to make the paper images for the mining engineers to look at. That would also fit with being made in Texas.
Some more evidence:
https://d28rz98at9flks.cloudfront.net/11388/Rec1964_132.pdf
Look at the list of manufactures.
Dwight
