I can't make John's serial board with His Z-80 Board
Marty
Boulder , Colorado USA
Hi All;
I have John Monahan's S-100 Z80 CPU Board Ver 02, and I am trying to make John's Serial IO Board Version 3 work together..
It will not Display anything on Tera-term, but Pressing any key on Tera-term makes it thru to the SCC IC..
But, if I take out the SCC IC and connect pins 13 and 15 together, I shows the correct letter that I pressed..
I have a Breakout Box, and I have been using that to see which signals are making it in and out..
I have also tried different combinations for the other pins (DTR, DCD, CTS and RTS)..
But, still nothing is displayed on the Screen..
I do not have the USB Upload/Download connected, Do I need that to make the SCC IC work, or does the Z-80 Board and it's EPROM Load the SCC IC ??
I am at a Loss, can anyone help me, find the Problem.. Thank You!!
THANK YOU Marty
Marty
Hi John;
Thank You for Your Prompt reply..
A couple more things, that I forgot to type in the above entry.. I do not have CPM, as that is why I am trying to make it work, so I can get CPM working..
That said, I did my first tests, using my Altair 8800 (8080) CPU, and putting into Ram the various test that would be needed for the Preliminary testing of the Serial Board..
And, Yes, I already have tried and used the Serial Board Page, as a guide to what I am doing.. But, Thank You for the Link..
So, I can see what the bits are doing, I have used 110 Baud, with everything else staying the same..
I can see that from what You have written, that I need to look at Your Printed Listing for the Code for the Z-80, to see how you have the Baud settings set..
When I do a Reset and a Run, I now get, (It took me awhile to find the correct wiring combination for P60 and P62, using an ohm meter and writing things down) the Leds to come on for the various signals, except for the indication of reading or writing to the Board.. That has never worked..
So, has my Problem, been that I need to change from 110 Baud to what the Z-80 Board is sending to the SCC on the Serial Board, I think I at first tried the obvious baud rates of 9600, etc., but they didn't work, and so I went to 110 baud to see what was happening..
So what settings did the Z-80 Board send to the SCC on the Serial Board, if I have not altered anything of the origional Z-80 code ??
I have found my Eprom Programmer, (which took awhile) but, so far I have not been able to make it work any more, It needs a working XP system, and I have not completely pursued that any further, but, I may need to see what I have in my Eproms and see if I need to make any changes to it's contents..
THANK YOU Marty
daver2
UK - Worcester
Hey Marty. How are you keeping in these funny times?
The SCC is purely software programmable so (unlike the 6402 UART) it depends what the darn software does with it...
What firmware EPROM code have you actually got in the Z80 card?
Looking quickly at the MASTER V4.7 listings (and John should be able to confirm or deny this), the SCC appears to be initialised (by the table at SCCINIT:) as 19,600 bps 8 data (I will have to work out the parity and stop bit configuration as it is not mentioned in the comments).
The use of the SCC appears to be dependent upon the setting of the sense switches on I/O port 0EFh (IOBYTE) - so how have you got these set?
Marty
Hi All;
A couple more things, I have Version 4.7 on the Eprom code for the Z-80..
Also, John, what is the difference between Your Serial Board Version 2 which You show in Your Serial Board Instructions and ver 3 which is the Board that I have ??
I am going to now Look at Your Z-80 code if I can find a listing for Version 4.7 and not Your latest 5.4 listing..
THANK YOU Marty
Marty
Hi all;
Thank You for Your reply Dave, I haven't heard from You in Quite some time..
I am doing fine for now, I hope You and Everyone is OK and doing fine as well..
I will try it at 19,600 bps 8 data bits and see what happens..
I don't know, I have not set any switches, except for F000, when I first reset and run..
I have now tried it with all of the Sense switches at '0000, and then did a Reset and Run, but it makes no difference..
I have also tried it at what You (Dave) suggested for Teraterm at 19200, also no difference..
THANK YOU Marty
daver2
UK - Worcester
Yes we are all fine this side of the pond...
Sitting in my bedroom working from home...
I have tracked down I/O port 0EFh (IOBYTE). It is on the S-100 Bus System Monitor (SMB) Board. Do you have one of these cards at all?
If not, I am having difficulty in seeing how the Z80 CPU card will work with the Serial card you are referring to...
The CO: routine first reads this I/O port and then branches based upon what it read. If the I/O port isn't there - what will the Z80 read?
Let's assume it 'falls through' to SDCONO:.
It checks the status of CONSOL_STATUS (I/O port 0) and sits and waits in a loop until bit 2 is set ('1'). If this port doesn't exist either, what will the Z80 read? The Z80 could, if this port doesn't exist, 'jam' at this point.
Let's assume everything is OK and the character is output to the TX data port CONSOL_OUT at port 1.
The Z80 then checks the IOBYTE port (0EFh) again looking at bit 5. If this bit is '0' it will output the character to your SCC chip...
There are a lot of assumptions that have to be true to get a working Z80 card with the monitor working without the SMB card.
Marty
Hi All;
No, I don't have that Board, I'll have to track down the Schematic, and see if I can build it, since at present I don't have the funds to buy it..
OK, that Clears up what I need to do or to get to make this Work.. Thank You..
Yet, in the back of my memory, I have had at least the Z-80 Board working, a few years ago or so, I just don't remember what I had system wise to make it work (read display)..
THANK YOU Marty
daver2
UK - Worcester
The other solution is to modify the Z80 monitor software so it ignores the IOBYTE and the serial console card and goes directly to your SCC.
That could make a more suitable solution for you?
Interestingly, the SMB is not mentioned under the "NEW USERS" heading of either the "Starter Z80/CPM system" or the "Better Z80/CPM system" on webpage http://s100computers.com/My System Index Page.htm.
John, is what I am saying correct or rubbish before I send Marty off down a blind alley?
I have got distracted now by the Dazzler II card and the Cromemco System I have on the bench at the moment...
Just taken delivery of an ESP8226. I am going to have a 'play'... I have seen an 8008 and a Z80 CP/M emulator available for it on GitHub. It is so cheap (a few GBP) that I plan to buy a few of them...
Marty
Hi All;
Thank You, Dave..
Ok, so I need to see about making my Eprom Programmer work with an XP System.. Which I have to build..
That should keep me out of trouble for awhile, Thank You Dave.. The software for the Programmer is workable only on an XP system and nothing newer software wise is available..
THANK YOU Marty
daver2
UK - Worcester
I hopped over to www.asm80.com. Created a Z80 project called Monitor.Z80. Imported the source code into the blank file.
Had to do a little conversion to suite the assembler:
TRUE EQU 0FFh ; Instead of NOT FALSE.
Remove all occurrences of @ and $ symbols in labels and variables.
Remove the extraneous "A," from "OR A,...", "AND A,..." and "XOR A,..." lines.
Fix a missing comma between the string "Menu Error" and CR.
It seems to assemble OK and generates a listing and HEX file. You should be able to compare these to what you currently have for equality before you start to hack about with the code...
daver2
UK - Worcester
I have hacked the monitor (I notice the text file is V5.5) to use the SCC only.
I seriously hacked CI, CO, and CSTS.
I also had to move the sign-on message, as the SCC is initialised AFTER the sign-on message is printed...
I am busy for the rest of the evening now, so I will forward on to you tomorrow.
Marty
Hi All;
Dave, Thank You for a job well done, even if it's not finished as of yet..
I am making an attempt to Install Windows XP on a Dell machine, hopefully, that will be another step in the correct direction for me..
Talk to You tomorrow, when I hope we Both have something to report..
THANK YOU Marty
DeltaDon
Dutchess County, New York, USA
Hi All;
THANK YOU Marty
Marty,
I have a TL866 and if you send me the updated HEX file and what eprom (2716, 2732 etc) you need programed I'll see if I can burn the chip for you and somehow work out how to get it to you.
Don B.
Marty
Hi All;
Thank You, Don for the offer, fortunately I got my Programmer to work, on my newly Installed XP system..
So, that is a step in the right Direction for me.. I am going to go to John's site and download the file for the Z-80, and see if I can make any progress..
Something to do tonight..
THANK YOU Marty
daver2
UK - Worcester
Marty,
Here is my first attempt.
I can't guarantee anything at all though :)...
You should be able to import the source file (Monitor1.txt) into asm80.com to be able to modify it yourself and regenerate a new HEX file.
My apologies to John in advance for the horrible hacks...
  • Monitor1.txt
  • Monitor2.txt
daver2
UK - Worcester
Marty,
I forgot to mention that the serial port is initialised to 38.4 kbps by default to save you a bit of time finding it out for yourself.
daver2
UK - Worcester
You will also require the hardware handshake lines cross-connecting don’t forget. RTS to CTS should be enough to get data out of the SCC. Set your receiver to 8 data bits, 1 stop bit and no parity to start with.
If you don’t see any characters on your terminal/emulator, have a look at the chip select line of the SCC when you reset the CPU card and check for a burst of activity with a logic probe, scope or logic analyser.
