Kevin Williams
Hi Everyone!
A lifelong dream has been fulfilled! I now own a 1968-era PDP-8/I! Sadly, I will likely be selling it, not restoring it as David Gesswein suggested that someone else would probably like to restore it, and I probably don't have the time now anyway. I bought it from an auction just last week, and it's even cooler than I thought it would be. It is not perfect, and probably won't power on in its current state for a number of reasons. One of which, is that I think it's wired for 208v, or three phase due to the amount of power supplies, and secondly, it did seem to have a rat living in it at one point. :-( However, it seems that most of the damage was limited due to the orientation of the backplane of the PDP-8/I board.
This machine is huge, and contains a TON of flip-chip modules in a second cabinet. There are also a ton of large connectors in the bottom of the chassis, which I'm guessing controlled an assembly line, due to some of the other items present at the auction. Also, I found a document stuffed in the ASR-33 I bought, which states the Lily Ice Cream Company, Houston, TX and a few dates of 1970 stamped on it. Certainly seems to fit the time frame, and I'm guessing all of the modules were used for A/D for sensors, etc. I'm also guessing the DF-32 holds (or held) the code to run this beast! I wanted to get a few comments on this machine as I know the PDP 8/I and the DF-32 would be of interest to someone, but would it be better to leave this machine in-tact? I realize its unlikely to be making ice cream again, but I also thought it is very rare for a system like this to make it all of these years without having one part pulled from it. It seems they disconnected all of the cables, stuffed them in the cabinet and stuck it in the corner for 20+ years!
Below are some photos, sorry they are bad. The cabinet is double-wide, and sitting on its side in my garage. We had to put it in the trailer on its side, but we can't get it up-right with two people, so I am either going to have to take stuff out of it to right the cabinet, or get a few folks over.
One odd thing I think is happening, but I can't tell for sure is that the DF-32 seems to be "driving" all of the modules on the left-hand side of the cabinet. The interface cables from PDP 8/I run to it, like I've seen pics of. The cables then leave the drive, and go to the other cards. Are they being treated as drive 1,2,3? Or are they just extending the bus off of the drive, since it was closer. I know it's hard to say, but I can't get deep enough into the cab yet to tell.
Either way, It's a beautiful mess of 1960's tech!
Take care,
-Kevin
Take care,
-Kevin
