dabone
I just picked up a 5154 Ega Monitor, I've been wanting one for a long time, but with the current pricing.... ouch.
Got this as a from someone local who bought a storage locker auction, covered in years of dust. Wiped everything down and popped the lid to inspect that everything was plugged in.
Firing it up I got the following that you see in the video that I linked.
Symptoms were the same after I replaced all the caps I listed.
Tube looks ok and unbroken. No spot in the front.
No Power LED, and no high voltage.
I already replaced c11,c113, and c114 in the psu.
I also replaced the following caps on the mainboard
c101,c116,c119,
c204,c207,c208,c254,c260,
c302,c312, c402,c405,c406,c409
PSU outputs some voltages when not connected to the mainboard, and doesn't squeal. I don't have the pinout for the psu to see what I'm checking for on voltage out.
I know the samsfacts are available, I'm just not sure I'm throwing $22 more into something that maybe a bad flyback or some other unobtainium part.
c101,c116,c119,
