maxtherabbit
R, G, B on CGA is not TTL level
yes it is
The simplest proper RGBI to SCART converter would consist of an EPROM with lookup tables, an 8 bit buffer and three 2 bit R2R resistor networks with load resistor, respectively.
The big advantages of an EPROM is are that the logic behind it is so trivial that anyone can understand it and that it is typically large enough to hold several variants of the lookup table.
Hi,
I wanted to know if I could connect IBM 5155 from CGA card to the commodore 1084S monitor or Philips CM8833, they are RGB (CGA) monitors, with the cable that is fine.
Thanks for your help.
1) buy an IBM 5153 monitor, it's too expensive and you rarely find it.
