Hi there - looking for guidance on whether its possible to get an IBM "Enhanced Corvette" (Differential SCSI Fast/Wide Adapter) to work in a Model 55SX. I've read ambiguous things online, and some futzing around with reference and options disk has got me to the point that I do now have it at least registered with the system, it now appearing in the View Configuration page of the ref disk, and the system boots (to floppy) with no errors. I should mention the weird proprietary original IBM hard disk is long dead.
Things that concern me are that -
View Config indicates the SCSI card's BIOS is not loaded
Running through Set Configuration errors, indicating that "An error occurred during the installation of the initialisation program"
Running Set and View SCSI devices indicates that "An error occurred while saving the SCSI data."
I currently have no way of attaching a SCSI disk (or expensive SCSI2SD gadget) currently so I don't know if that's the cause of some or all of these errors, but before I waste money on a hopeless cause maybe someone could give me a steer?
Cheers!
Cheers!
