It's not clear from your photos, but it's very likely that one of the head supports has broken. If that's the case, then you'll have to find a replacement head assembly and install it. Getting close on azimuth is probably good enough since Tandon was never fussy in that respect (I sometimes wondered if they checked it at all). But alignment will have to be performed.
The damage to the disk is consistent with catching the edge of the head on the media.
On the other hand, if there's just a bit of foreign material (e.g. decayed foam) gunking things up, you might just luck out by removing it, cleaning the heads and giving things a spin.
If I were you, I wouldn't toss the drive just yet. Remove the PCB and see what you can see.
