Ole Juul
A switch is indeed nice, but I think you've got it backwards; you don't want to cut a wire, you want to short out the sensor, and you want to simulate unblocking the LED-sensor path...
Yep, I probably just put the switch wires across the sensor. It was a while ago and I just remember that it was obvious when I looked at it. (I get your question now ) I have the drive that I did that to, but haven't been motivated to put it in the DOS boxes I'm using now (or modify these) since I don't write nearly as many disks as I did back then - just a bit of "tweener" work now.
