| VCF SoCal | TBD, 2027, | Southern CA |
| VCF East | TBD, 2027, | InfoAge, Wall, NJ |
| VCF Latam | TBD, 2027, | Bahía Blanca, Argentina |
| VCF Pac. NW | TBD , 2027, | Tukwila, WA |
| VCF Southwest | TBD, 2027, | Westin Dallas Fort Worth Airport |
I'd like to bump this post - I have a older 5160 board that has the MK37000 and MK38000 - its a 64K-256 board upgraded to 640K - I have attempted to burn the May 86 5160 bios to U18 and U19 and I cannot get the system to POST - I have used the older 11/82 BIOS and it boots fine. I have also made XTMEMTEST and the Ruud's test ROMs without issue - I am also trying to use the 27C256 Chips from TI - they are true chips and haven been UV erased prior to programming - I have also verified the contents of the ROM's when I have burned them -can I upgrade my 5160 XT (256KB board) to accept the new bios which supports 720K and 1.2mb disk drives? What is involved? Right now I have to use a card with onboard bios to utilize a 1.44 drive.
You will be referring to the web page at [here]. I just now put the 05/09/86 revision from that page into PCEM v17, and watched PCEM boot into Cassette BASIC.Anyone have any idea if The May 9 1986 ROM from minus zero's website is useable? I am not sure I am doing anything wrong as I am using the 32K ROM files from the site -
Looking at the diagram at [here], one of the differences between the '82 and '86 dated BIOS' for the IBM 5160, is that in the '86 versions, the BIOS is extended into ROM U19. I wonder if there is a problem with the U19 socket/soldering (or tracks to it).I'd like to bump this post - I have a older 5160 board that has the MK37000 and MK38000 - its a 64K-256 board upgraded to 640K - I have attempted to burn the May 86 5160 bios to U18 and U19 and I cannot get the system to POST - I have used the older 11/82 BIOS and it boots fine. I have also made XTMEMTEST and the Ruud's test ROMs without issue - I am also trying to use the 27C256 Chips from TI - they are true chips and haven been UV erased prior to programming - I have also verified the contents of the ROM's when I have burned them -
Let me get the older BIOS installed back in the machine and I will report back shortly..... yeah I did see the memory space was spread - which got me thinking that perhaps I was burning the rom's incorrectly - standby and I will go check -You will be referring to the web page at [here]. I just now put the 05/09/86 revision from that page into PCEM v17, and watched PCEM boot into Cassette BASIC.
With the 11/08/82 revision BIOS in place, if you run the 5160ROMS tool at [here], does 5160ROMS give the expected result?
I.e.
So sorry this took so long to get back to you - but - I wanted to be sure I could run the 5160ROMS file and screen capture it - the result is - YES the U18 and U19 ROMS are seen with the 11/08/82 ROMS installed in the 5155 (aka 5160) MBYou will be referring to the web page at [here]. I just now put the 05/09/86 revision from that page into PCEM v17, and watched PCEM boot into Cassette BASIC.
I.e.
