ardent-blue
- Joined
- Jan 2, 2015
- Messages
- 479
Wow, quite complex message.
Any 387DX will work, as long as it is rated at least as fast as the 386 it supports. For a 20MHz system, any 20-40 MHz 387 will do. Though dropping a 40MHz rated 387 into a 20MHz system would work, it won't crunch numbers any faster than a 20MHz 387
That decomposing black foam is a common occurence in Model 95 systems as well... It's purpose is to ride along the top of the adapters, forcing the ventilation between the adapters so as to cool them more efficiently.
The 80 is the last overpressure system in the PS/2 that I am aware of. The 90 uses a combo adapter/complex fan, but the PSU has a common outward exhausting fan. The 95 has two fans, one is the long side wall fan, it helps ventilate the adapters, and the PSU exhaust fan, which does the drives, memory, and complex.
http://ps-2.kev009.com/ohlandl/8580/8580_PS_01.html
Al Savage didn't use a security torx bit, but I would bet it is a T15 or a T10.
