BrainStruck
Hi,
I recently acquired a dead IBM PS/2 Model 50 Z. Upon initial troubleshooting it appears as if the power supply is the main problem. When turning on the computer, I get no video, no beeps, and a high pitch whine out of the power supply. If I unplug the power supply from the motherboard and power it up there's no whine.
Power Supply Details:
ASTEC AAS13621
IBM FRU P/N: 90X9366
With the motherboard unplugged I checked the voltage at the motherboard connector and I'm getting: -11.31v (-12v rail), 11.79v (+12v rail), and +5.2v (+5v rail).
With the motherboard plugged in, the PSU whines and when I check the voltages I get: -0.01v (-12v rail), +1.63v (+12v rail), +0.77v (+5v rail).
I replaced all of the caps on the low-voltage side. There are 2 power resistors that get very hot. So hot they melted the tube the switch wires run through, faded their labels so bad I can't tell what they're supposed to be and cooked the board enough to leave burn marks on it, and lifted the pads they're soldered to. One tested @ 8 ohms and the other @ 16 ohms.
I've attached a photo of the board calling out some general notes. I'm wondering if someone could point me in a direction. I have a basic concept of how this power supply works, but I can't seem to figure out which component is emitting the high-pitched whine, or if the whine is the cause of the problem or a symptom.
Thanks in advance,
Brian
ASTEC AAS13621
Thanks in advance,
Brian
