Chuck(G)
25k Member
I use an internal LS120 drive with an IDE to USB adapter. Even shows up as A: in Windows.
That's certainly another option. What brand of IDE-to-USB adapter are you using?
There were certainly the black "slimline" LS120s made for laptops, but I don't know about the full-height ones.
I'm curious about the USB "Superdrive" LS-120 made for the Mac community. They appear to be an IDE (could also be parallel, I suppose) with a USB port replicator attached. Anyone know for certain?
The iMac look USB Superdrive is an internal IDE drive attached to a IDE to something adapter wrapped in a colorful plastic shell which is attached to cable that has USB on one end and some strange connector that attaches to the drive. There is a youtube video of someone disassembling a 1999 model which briefly shows the internal IDE connector.
That's the one I was talking about. That weird connector (looks like a shrunken SCSI connector) looks as if it might have some active devices in the plug end. Those units any good? You can get them for a fraction of what a regular IDE LS-120 drive sells for.
I still have a pile of new Caleb IDE drives. I wonder if an IDE-to-USB converter will do the trick there. If so, I've got my answer.
Off-topic, but NEC PC-98 DOS is NOT DOS/V. DOS/V refers to Japanese DOS for PC/AT compatibles with VGA cards.I checked that with my SmartDisk external USB floppy and it handles 720K (as well as DOS-V 1.23M floppies) very nicely.
Glenn, I still use floppies quite a bit, in particular to transfer data to older non-network equipped machines. My latest system lacks both PATA (so I can't use an LS120 drive) and legacy floppy interfaces--just has USB and SATA. I despise littering my workarea with little boxes on cables.
Do you hae any suggestions?
Okay, I ordered a couple of them. Will try them with both LS120 and Caleb drives.
I also ordered up stuff for my USB-floppy-in-a-card-reader slot suggestion. If it doesn't work right, I can always use it in another system with regular floppy support.
