Chuck(G)
25k Member
I am late to the discussion but how about PCIe PATA card? I am sure cheaper ones can be found and going forward it may be the only solution.
As for slimline to HH - I searched high and low for these a few years back (to use slim line ls-240 drives) w/out any luck. Not a very common item, even though it seems like a no brainer...
If that PCIe card is anything like the very similar PCI card that I have, there can be some real problems. I tried the VIA PCI SATA+PATA card on one of my machines and it refused to boot, complaining about SATA controller failure. As nearly as I could figure out, the BIOS got confused over the motherboard VIA SATA controller and the one on the PCI card.
I'll keep the form posted on what does work.
