Okay, I built a copy right now with these options:
and it powers up on a 4.77MHz 8088 fine. DOS loads, and FDISK does too. I'll admit to using a drive that works already, but I'm not sure I have anything working but unpartitioned.
The wording "non-system disc" doesn't come from this BIOS. It seems like it might be baked into the boot sector of on discs with a typical floppy-style boot sector... I wonder if the disc is configured in a way that's confusing the system-- like FDISK is looking for a hard-disc style partition table in a floppy-style formatted drive?
I wonder if a FDISK /MBR would help recover normalcy on the drives. What do they look like on another machine, i. e. in Windows Disc Manager?
MAX_SPT equ 63
MAX_HPC equ 16
MAX_CYL equ 1024
%assign DISPLAY_CH376S_ERRORS 1
%assign INJECT_INT19_HANDLER 1
%assign ALLOW_INTS 1
%assign DOUBLE_WIDE 1
%assign SHADOW 1
COMMAND_PORT equ 0xE4
DATA_PORT equ 0xE0
COMMAND_PORT_2 equ 0
DATA_PORT_2 equ 0
WAIT_LEVEL equ 10
