I am able to load di1000dd.sys high on my tweener.
For some reason i think that was the one i could not get to load high when i tried a long time ago, But it doesn't bother me i just let them load low, Do what i got to do and then unload them.
I use USB flash drives on my DOS tweener regularly using the Panasonic support mentioned by krebizfan.
No idea about WinME - it was deeply unpopular here, and in fact I've never seen one in the flesh. Apparently it looks like W2K, but whether it inherited W2K's excellent USB support is another matter entirely.
Back in the day the Optiplex GX1 was almost a standard around the office spaces, however I don't recall it ever supporting USB in its original configuration. In that USB was fairly new in the late 90's, you were left with the choice of installing an after market USB card in order to run that USB mouse or scanner. USB 2.0 didn't enter the playing field until the early 2000's, you may be dealing with USB 1.1. Also, IIRC, the first GX1's came with DOS 6.22 and/or Win 3.1. Since you are probably dealing with a Pentium III, I would go with WIN 98 or WIN 2K - better driver support. Make sure that you have the correct driver set for the GX1; most probably USB 1.1.
https://www.dell.com/support/home/us/en/04/product-support/product/optiplex-gx1/drivers
Yes. And you have to install the USB patch to install the AMD K6 patch.
Why downgrade from Win98 to Win95C?
Windows 95C will support early USB mice and keyboards and some other devices if one is lucky enough to find dedicated drivers. It does not work with USB 2 controllers or hubs.
Apart from DOS-based games and utilities, I feel there's not really a compelling reason to use win9x much now.
Duh... why run DOS games from Windows?I have a win98SE to run dos games such as Doom, Quake, Wolfenstein-3D and similar.
I dunno about that, I installed Win95C on a K6-2 system I once had, and I never installed any USB patch, only the AMD K6 patch. Best to my observation, the system worked well but I never tried USB.
I like to have my retro systems to be both useful and fun, but that's just me. I want to live back in time. So I do haphazard things like trying to modernize these systems to compete with the awesomeness of WinXP in the offline side of things.
Yeah, it's nice when you can get old systems to do new things. I like experimenting with that kind of thing too.
For example I recently found out how to enable IE8 on XP to use TLS 1.1/1.2 which gets it onto most https websites. I'm sure there's lots of other tweaks out there as well.
How did you do it?
Easy. For some it is a nostalgic thing. Wrt to usb Win98 with fixpacks(works fine for 98 first edition and SE) or ME are a far better option using a dos backed Windows.did you install win 95 ???? why ?
the best way to use XP online is with the Pale Moon XP builds - see here: https://msfn.org/board/topic/177125-my-build-of-new-moon-temp-name-aka-pale-moon-fork-targetting-xp/
