Hello Rick,My Kaypro 2X has a 21/84 board. All I need to do is solder a connector to J9 to use the KayFreHD?
Thanks,
Rick
you have to populate the connector J9 and some TTLs (U28, U31, U37....)
Frank
Thanks,
Rick
Hello Rick,
Frank
Would it be easier just to use the Z80 L shaped adaptor with this machine?
jaquinn: The board is based on the design Ian did for Universal Board equipped Kaypro models like the 10 and the 4/84.
Have you tested your design with those boards? I'd be curious to see if they work. (probably will)
g.
