Looking for Franklin Ace 1000 ROM images
One of my ACE1000s has a keyboard with an EPROM. I've desoldered it and read it in; the image is attached.
Note: the original EPROM is an Intel 2758. It appears to be a single-voltage 2708, with a pinout matching the 2716 minus A10 (pin 19). I grounded pin 19 and read it as a 2716, so the resulting ROM dump is doubled. You should be able to burn it to a 2716 as-is, as pin 19 is grounded on the keyboard PCB.
I'm currently trying to fix an old serial terminal (https://www.vcfed.org/forum/forum/t...elcon-ambassador-iv-vcs-204-portable-terminal) and its keyboard looks like a very close cousin of the Ace, with even the same 2758 EPROM (though this one is National Semiconductor) - Does the Ace keyboard also use the General Instrument 19-04592-013 as the controller, or a different variant of the GI 4592?
For some reason I'm not able to read out the contents of my ROM. Telling my TL866-II to read it as a 2816, it never reads the same data twice. I'm trying to just set it up on a breadboard to see one byte at a time, but not having luck with that so far either.
I guess I never updated this topic. A member of this board or another sent me a bin file they said was for the keyboard. i asked some questions but the member never replied again. as luck would have it that rom image worked perfectly and i was able to fix that franklin 1000/1200 keytronic keyboard. As i mentioned earlier they connected the ribbon cable backwards so it blew a couple ttl chips and capacitors. But thankfully i was able to fix that computer and get it back to its owner.
I'm currently working on repair of a Franklin ACE 1000 80-column card. Does anyone have images of the slot and character ROMs?
So I was working on my (Working) ACE 1000 and I decided to clean the mouse poop off the motherboard. In the process, I removed the ROMs and went to read them all in.... Sadly, in the process, I accidentally wrote to the ROM in G7 before reading it out. One would think it wouldn't do anything, right? Well I did a test with the G8 ROM where I loaded a different ROM and hit write -- it errored out. But then when I loaded the correct ROM into the buffer, I did a verify and the first byte was changed! So I am assuming the first byte of the G7 ROM was changed as well..... and this happened before I read it out and saved it, so I just don't know what it should be.
It is labelled "G7 v2.0 1331404" and is the ROM for E000h.
Does anyone have a copy of the ROM images (specifically of the E0xx v2.0 ROM) I'll need to replace this PROM with a EPROM ......
Also if you have an Ace 1000 with the 2.0 ROM in that socket and you go into machine language monitor, can you show me first few bytes of E000 holds? I can probably hex edit the file I made to make it correct again.
At this point, my machine no longer boots -- just stops at the garbage screen at power-up. It may not be related to the ROMs as the mouse poop has caused some corrosion on some of the other chips and me disturbing those chips might have screwed things up. I may end up trying new chips in those sockets just to see if that helps as they are all normal 74LS logic stuff.
Confirming what E000 ROM has it in would be the best -- but also if you pull the E000 and D800 ROM from the machine I'm curious what that does to the boot sequence. Total stoppage or a crash?
Thanks!
Just looking for the code out of the 24s10 prom on the ace 1000 color board its a ti 24s10 256 by 4 bit prom
Thank you
Tom
Could you share that file here or upload it to archive.org by chance?
Does anyone have the Frankly Ace 1000 Softboot ROM and the boot floppy? I'm super curious to see how this works after David Murray recently showed off a Softboot Franklin Ace on his recent Franklin video.
If no one here responds or has any, I'd check in with the AppleSauce Discord. Someone's likely to have archived them.
I was a software dev at Franklin. Might be a longshot but I’ll see if I’ve got a copy of a softboot ROM image around. If not I can check with some of the hardware guys.
FYI: The Softboot ROM implemented enough of the DOS file system to find a specifically named file, load its contents into a RAM bank, lock it and jump to it. It was written by Dave McWherter.
So I might have something for you. Attached is an intel hex dump of what I think is the boot ROM for a Franklin CX portable (unreleased portable that a few of us were given at the end, this image came from mine.) The CX was a softboot machine I’m pretty sure. It’s marked v1.4 of 9/17/1984.
Figured this might be useful for this thread. I recently picked up an ACE 100 (not 1000) that I am trying to fix. I dumped all the EPROMs. All but one compares well to the ones Adrian posted on archive.org, however G2 on mine is version 2.0, where Adrian's was v2.2. I'm wondering if that was the ROM that was tweaked in response to the Apple lawsuit?
Mine seems to want to function, it posts and beeps, but the text on screen is wrong. Hoping G2 2.0 is good, I haven't found it anywhere else online.
Here's the archive I made.
I don't think this is a boot ROM. I've converted it to binary and tried, but it didn't work. I've examined the contents, and there are strings such as "PRINTER", "Baud rate", "Parity". One of the instructions is JSR $C213 - it jumps to slot 2 ROM, which is usually used by serial cards. Assuming the last 6 bytes are NMI, Reset, and IRQ vectors, they don't make sense - they point to $4898, $F34C (which is $C2 - invalid opcode), and $14C2.
I'm attaching the binary file resulting from the Intel hex.
As for the difference between G2 2.0 and 2.2: Franklin ACE 100, 1000, and 1200 share the same ROMs - modified Applesoft with lowercase support but removed cassette routines. G2 is the F8 ROM, and the only difference is the welcome text: "ACE 100 v2.0", "ACE 1000 v2.2" and "ACE 1200 v2.3".
Yeah, you're right. I didn't look closely enough as the file name even include "io" so it's probably the serial card.
I messaged one of the hardware guys who I believe worked on the CX design to see if he might have anything of use. Will post when I hear back.
