pbirkel@gmail.com
An as-shipped memory configuration for an 11/45 would have used either the MF11-L/LP, MM11-U/UP, or MF11-U/UP according to DEC configuration literature. These were all multi-module low capacity stacks so several stacks would have been installed, requiring additional special power regulators (which you don't have), unique backplanes (which you don't mention having) and space. Reference documents:When you have time, can you please tell me the make and model of all memory related components you have? For example, if I just buy memory I suspect it won't work without a "memory control" as well. I'm hoping to find some on vcfed marketplace or eBay.
If you want to use DEC memory then your best bet is MOS memory installed in a standard DD11-D backplane (as suggested by others) plus the correct power regulators for that backplane. For the backplane, see:
For MOS memory probably your best bet is some variant of the MS11-L; the MS11-L is still "around in the wild". A good choice might be the M7891-B (64Kw). There's an equivalent half-populated M7891-L listed on eBay at the moment: https://www.ebay.com/itm/225768623109 (the listing states the full 128K capacity of this board but it's not been fully populated). IMO a fair price would be half of the listing price. Reference document:
I suggest that you intensively study your current configuration as it doesn't seem to be complete, at least power-wise.
In case it's not already clear, this system will require lots of TLC before you can "just plug it in" and expect anything to "just work". I strongly suggest approaching it step-wise with all modules removed and testing/verifying all power supply rails under load. If you're not familiar with reforming electrolytic capacitors then that's a topic that you'll need to "get under your belt" before you simply plug in those H742s (yes there's an internal regulator in each that include an electrolytic capacitor that should be reformed).
If this all sounds "too complex", that's because it is :->. That's how it was 50 years ago ...
