Chuck(G)
25k Member
Or you can use a program like Procom Plus and set the data rate to 1200 8N1 (many mice) or 2400 8N1, move the mouse around see what codes are returned.
A good program for testing the mouse might be the Norton Commander.
What is mouse.lan? I can't say I've ever heard of it.try to update mouse.lan, idk =\ it's would be useful for it and could solve the issue
So just 360k, 720k only then? I think the rest are all HD.Far as I know its double density only on 1000 line stock, but i'm a little fuzzy to all the models. Miss my 1000RL.
Ok ok.. I think I'm starting to come up to speed.IMA files are raw sector-by-sector data. Winimage should handle them.
tried making a new 720k image and putting some softwares on it, but the GoTek doesn't recognize it.
I bought my Goteks a couple years ago IIRC. At that time, I did re-flash the firmwares, though again I don't recall which 3rd party code was used. When the Gotek in the EX powers up, the LED display briefly showx "F-F" - is that for FlashFloppy?Has your GoTek been modified with a third party firmware like HxC or Flashfloppy, or are you using whatever the factory is slapping on them now?
The EX will not work, full stop, with a 1.44MB image because the data rate the emulator will switch to will be wrong. There are techniques if you’re using the HxC or Flashfloppy firmwares to make 2MB-ish images that *do* work, but they’re nonstandard and require a device driver on the Tandy side.
Thanks for the info re: 1.44M images, I wasn't aware that the Gotek would change data rate. So do the physical 1.44 drives also run at a higher rate?
In fact, FF did have OLED suport at the time, and I went ahead and ordered a display to use in one of mine. (On first try, I'd accidentally ordered the wrong Gotek model, a model that lacked the buttons & LED display and had planned to "convert" it to a PC-useful version in time as the basic hardware is the same.)Second that on the OLED. Easy to install and actually gives some information.
A small bead of hot glue worked well on my 2 units.Btw, any suggestions on fixing the OLED in place? There are no provisions for this in the Gotek case.
