Smack2k
OK,
I moved my 5160 from its old home to my man cave...plugged it in and turned it on..
I get one loud beep and then two beeps...it seems to keep running after that, but
My 5153 Monitor just has a rolling picture and whatever is on the screen isnt much info. I tried the Vertical and Horizontal Holds to no avail..
Also, and more important, when I turned it off and reached in the back to pull the power / keyboard and monitor, I could feel the electricity on the outside of the case, on the metal part of the monitor cable and on the serial portion of the keyboard plug-in (The DIN was plugged in).
Once I unplugged everything, it obviously calmed down...
Do I need to get inside and reseat everything or is there something else I need to look at?
1 long and 2 short beeps point to Video Adapter, but why all the electricity as well? Something not seated right? I am cracking it open tomorrow after work, but wanted to see anything else to look for from you guys..
