falter
The DTR pin is is pretty much standard for terminals (DTE), which generally is used to indicate to communication equipment (DCE) that there is a powered-up terminal present. Some modems, will not talk to a device not signaling DTR. DSR corresponds to the DTE signalling that it's present.
Here's a great tutorial on RS232 signalling.
There's no reason that the CT1024 can't talk to your MSI box--you may just have to slow things down a bit--2400 bps would be more appropriate for the time period.
Thanks Chuck. I can slow the MSI down to 110, which is the speed my CT1024 is fixed at. But I get absolutely nothing when I connect the two. Now.. I don't have a male to male db25 null modem.. i have a male to female db25 to db9 and I'm trying to use jumper wires to go fr the db9 to the female db25 on the ct1024. I connect ground and tx and rx.. but there is no reaction at all from the terminal when the msi is switched on.
