Multitech MGA adapter
k2x4b524[
Tacoma, Washington, USA. Zip code 98404
New beastie came in the post today
A full length Multitech MGA/CGA/EGA adapter - At least that is what the description
The model is a Multitech PB85005-2A
Has 8 16kb chips on board - so 64kb, and a rom.
I'm wondering if this thing is Hercules capable, but can't find squat on it at all.
What is the difference between Hercules and MGA or is it 2 definitions of the same thing.
I really don't think this is an MDA, as it's got more ram and again, the rom chip
Anyone got any insight?
"MGA" is Hercules, it's just MDA with graphics support.
Usually if it's multimode, there will be a bunch of switches on the back panel to select the display type.
Some fancier ones are automatic-ish or software controlled like some of the ATI Wonder series.
Edit: Quick note regarding video ram, if they're 4116's or equivilent, then that's only 16KB of RAM.
I'll have another look at it later tonight.
Interesting thing about it is, in the 5150, it boots as a mono adapter
Plug it into the 5160, even set to mono, no dice, just the beeps of no video
Bit of an update.
I'm about to throw the thing out the window.
I cannot get the graphics part of MGA to work, at all, on any of the cards i have
SimCGA just makes the screen go black
The SetCGA command afterwords, does the same thing until i type cls
I am probably doing something wrong with it, unless i can figure it out soon, i may just end up paying ebay prices for an ega monitor or cga card + matching monitor.
How does one properly setup a MGC + Mono adapter + Monitor?
There should be no setup beyond getting text to display.
To test, try to find a program (e.g. Microsoft Flight Simulator) that supports Hercules graphics mode directly.
P.S. I've never seen a Multitech -2A MGA. Most of them out there are the -7H models. I wonder if the -2A one is a very early (read: incompatible) model.
Just to be clear on something: "8x16kb" means either 16 Kilobytes if by "kb" you mean "kiloBITS", or it means 128k if by "kb" you mean "Kilo-Bytes". (8x8=64, 8x16=128. Maybe you should just post a photo of this thing. As for the ROM, that is probably the character generator ROM, not a BIOS ROM. All video cards of that era have one, including MDA and CGA cards.
There are photos of similar Multitech cards online but none of them are clear enough to completely make out the memory. One version has 8 18 pin sockets, which implies it came with 64K in the form of 4 sets of 4416 16kx4 chips, while another one appears to also have 64K made out of a single bank of Fujitsu 8264A 64kx1 chips. Either is correct for a Hercules card-compatible card. And, yes, if your card looks like either of those two it has a character ROM, not a BIOS ROM.
I actually got the thing to work with simcga, so i'm sure it is a herc clone. The game i got to work was Monument Of Mars
Another thing, IBM Advanced Diags shows both an MDA and a CGA adapter, so i think this card is autoswitching based on what the system expects, like the dip switch set to cga, it will put out CGA
Eudimorphodon - I will post a pic either today or tomorrow of the thing, and its floppy companion i have, a multitech PB85020 serial, clock, floppy controller.
