modem7
10k Member
Here is a suggested crude test:
First, we start the test using fewer cylinders and fewer heads.
1. In the computer's CMOS SETUP, set the drive type to type 2. (Type 2 = 615 cylinders, 4 heads, 17 sectors per track)
2. Create a DOS boot diskette containing SpeedStor 6.5
3. Boot from the diskette, then execute SpeedStor 6.5
4. Select [Diagnostics].
5. Select [SeekTest]. You may or may not hear the drive's head assembly moving.
6. If that test passes, try the ReadTest.
If that all works, we then inform SpeedStor that a CP-4033 is attached, then redo the SeekTest and ReadTest.
7. [Quit] to go back to main menu.
8. [ManualSetup] then [Type] then [DriveOne].
9. Select CONNOR then CP-3044.
10. Return to the main menu then redo the SeekTest and ReadTest.
