I've received a new transformer from Dalbani, KFS-21288. Unfortunately, this new FBT doesn't seem to be pin-to-pin compatible with the original FBT. More details are below.
Ohm meter check on the original FBT shows the following, as I posted earlier (
https://forum.vcfed.org/index.php?t...onitor-daewoo-dm-120mwa.1242137/#post-1304169)
In particular, pins 1-4 of the original FBT are primary.
But, for the new transformer, pins 5-8 look like the primary side; a high voltage diode test tells that pins 1-4 are connected to the HV red wire.
Interestingly, ohm meter readings between pins 8, 7, 6, 5 of the new FBT are exactly the same as the readings between pins 1, 2, 3, 4 of the original FBT (note that the pin order is reversed). So, perhaps, one could guess that these two FBTs might have "compatible" primary sides (???).
The ohm meter readings of the secondary side (pins 1-4) of the new FBT are as follows:
1 ------------ 2 ------------ 3 ------------ 4
2.27 ohm 0.37 ohm 0.62 ohm
These values are different from those of the original FBT shown above. I think comparing the ohm meter readings directly is not the right way, especially because the original FBT has a defective winding. But, even the order of the pins along the secondary winding is not compatible.
From a positive viewpoint, the ratios of the secondary winding ohm values are very similar, as shown below:
4.49 : 0.61 : 1.05 = 100 : 13.6 : 23.4 (original)
2.27 : 0.37 : 0.62 = 100 : 16.3 : 27.3 (new)
So, very very hopefully, the new FBT might have compatible secondary windings which are made with thicker wire... I hope I correctly remember what I learned from my freshman physics course (the most advanced course related to electronics I ever had ^^), that the wire thickness does not change the inductance of a coil...
As another observation, the size of the new FBT is slightly bigger than the original, as shown below (the top is original, and the bottom is new). Perhaps this justifies the use of thicker wire? Their physical pin locations (pitch and radius) are compatible.
Somebody who owns this VDU has confirmed the model number "MMF-81011" on the original FBT. Dalbani's eBay page (
https://www.ebay.com/itm/400908964962) says that the new FBT, KFS21288, replaces MMF-81011. I don't understand why the pinouts are completely different, in spite of this information. Could it be that my VDU has a different internal revision?
If it is a reasonable guess, then perhaps, hopefully, could one even expect the possibility that the new FBT might work for my VDU just by permuting the pin connections? I think this might be too wishful...
I didn't do it yet, but perhaps I may try to connect the primary part of the new FBT to my VDU mainboard, with pin numbers permuted, to do the same tests I did earlier. Especially to see whether the excessive current drain is changed to normal, and HOT collector voltage waveform becomes normal. Would it make sense?
