ineverland
- Joined
- Oct 28, 2011
- Messages
- 57
This is a quick view of the progress to solve my problem.
When I first received this isa usb adapter,my XT 5160 can not pass the POST test."Press CTL TO start E-DISK" is printed because the rom bios failed to detect CTL key pressed.F6400 ROM ... is printed is because of the wrong address decoder of it,the rom bios is mapped in several addresses.
This is the screen when I remove the w27c512 rom chip from the adapter,and load the dos driver of it in CONFIG.SYS,usb disk can be recognized as C:\ disk.
When I fixed the addressed decoder with a 74ls11,and modified the rom bin file to jump over the CTL key detect routine,I tried to boot my XT 5160 from usb disk.
This is the "MIssing operating system"error I got.
the modified version added a 74ls11
This is some tests when I study on the rom bios source and tried to modified it to work.I used a freedos copy.I tried a lot of disk management tools to test.
stack overflow error
can't find command.com error
This is the final screen when I succeed to boot from usb.
This is the modified version.
this is the modified bios rom.
View attachment burn(w27c512).zip
Hope it's useful.For some strange reason I can't make it work again now,But I believe you can do it after some careful research.
