Hi there- I read somewhere about taking precautions soldering direct on to the motherboard - I saw a safer method proposed on minuszero.net which suggests soldering to the old legs.. is that the approach you took for these trimmers? cheers! AndySorry I thought I updated this thread but I only mentioned briefly the new replacement I used in my other repair thread I opened for the whole board. See the first post:https://forum.vcfed.org/index.php?threads/breathing-new-life-into-1981-ibm-5150.1239263/
The pots I used were these 9-120Pf Sprague variable caps: https://www.ebay.com/itm/202908102783
That was in regard to the filter capacitors on the motherboard, and I see on my website, "If possible, use the technique shown at here, because on a 5150 motherboard, soldering the ground and/or power lines on the PCB is problematic, and you could end up damaging the PCB.'' That sentence is targeted at those with nil or poor soldering skills. A competent solderer would ignore the suggestion, knowing how to deal with ground/power joints that are problematic. And even someone with little soldering experience may decide to go and do some internet research on the subject.I saw a safer method proposed on minuszero.net which suggests soldering to the old legs..
