Ttpilot
You and Dwight were correct. I pulled the 79L12 and checked it by itself; with -12V on the input, I was only getting about -5V on the output. I pulled C1 and C2, and they were both bad. I replaced all those and found no shorts on the -12V rail. I powered everything up and all three power rails are working properly. The Vcc and -Vcc on the 1488 ICs are now reading correctly, there is +5V and +12V to the disk drive power connectors, and card connector pin 52 is now reading -16V. Everything looks good at this point.No problem. If it was simple, everyone would be doing it and there would be no reason for us to be here...
The short circuit between the +/-16V rails would certainly have driven the switched mode power supplies daft! It was a good job they have overload protection! You could have done some real damage there...
R32 reading 0.4 Ohms instead of 330 Ohms is (more than likely) a red herring I am afraid. All it probably indicates is a short circuit elsewhere between -16V and GND. Keep looking - you have done an excellent job so far and you are close to the finish line to getting this beast running again...
I suspect - with the short circuit between the +/- 16V rails - you may have inadvertently reverse-biased some of those tantalum bead capacitors. If (say) the -15V supply shutdown, this could put +15V across some of the capacitors (relative to GND) that are on the -16V line. My recommendation would be to recheck the pesky capacitors again. I am also not sure what this would do to the voltage regulators either.
Now I'll have to troubleshoot the cards. I'm hoping the Compupro CPU-Z and RAM-17 are okay. They only use the +8V rail. The Morrow Designs DJ/DMA fdc uses all three rails, so there is the possibility of problems there
