im using machine only support NEC 3142 and NEC 5146 (40 MB)hard disk ST506 interface .how can i use another hard disk which are available now days instead of these .what hardware and software changes i have to be made for that.
Hi
There were differring types of interfaces from the computer side.
Most popular for this time period was the WD1000 type interface.
This type of interface is actually similar from a software point of view
to the more common IDE interface. There was another HD interface
used on the AT type PC's that was not compatable that was used
for MFM drives.
The main issue with using a IDE is to format it and to create the interface.
Many IDE drives can automatically configure to the same head and cylinder
numbers you need.
Another possibility is to us a CompactFlash. These can be configured to
look like a IDE drive. There is a way to specify to the CF what you want
the drive to look like. One can look this up in the CF specification that
can be found on the web someplace.
Both of these options can be done with a minimum of additional hardware
because all the IDE needs is bus buffers and an address decoder. This
will most likely be software compatable as well.
CF cards and IDE have another issue and that is that they number the
cylinders from 1 instead of 0. This can often be patched by adding an
increment to the code that generated cylinder number.
Another option would be to locate another MFM drive of similar size.
The problem is that 8 head drives ( what you have ) are just not that
common. The ST251 is an 6 head drive and could be used with software
changes. It does have the right size and these are more common.
Many machines had tables somewhere to be used to calculate drive
head/cylinder/sector. If this can be located, one can simply change
the values.
One does have to be careful about stepping speed. If the system is
not using auto stepping with the NEC, it may expect a faster step rate
than the ST251 can handle. This can usually be fixed by using the auto
step mode.
These both require a few days of decoding the HD software driver. I've done
this for an Olivetti M20 but it is still a lot of work.
Dwight
