olePigeon
This guy had the exact same problem I did, but never found a solution:
http://www.techtalkz.com/apple/313629-transwarp-iie-revisited.html
Out of curiosity, I swapped the memory chips on the Transwarp card. All it did was make it reboot before the game even finished loading (though just Ultima.)
It is very doubtful the capacitor replacement would solve your problem...BTW: It looks like there are more than 20 capacitors on the TW PCB...Well, looking at it closely, I noticed that one of the capacitors is bulged and leaking. I'm gonna recap it. Only has 4 caps, but it's worth a shot.
What chips?!! Would you post a photo of your card, please.I've tried swapping 64 chips so far, and the issue is the same.
It only has 8 RAM chips, but I have 3 or 4 RamWorks cards that use the same type of chips. I was swapping them 8 at a time.
Looks like this, but with 1.3 ROM:
The idea is completely different but I doubt that the CPU could be faulty in that way anyway, and last but not least, the 65C816 will not work in the TW!Oh, derp! Thanks for the idea. I'll swap the CPU from my IIgs and put it in there. Looking online, the 6518 should work in the Transwarp. I'll give it a whirl.
