daver2
10k Member
So, going all the way pack to posts 1 and 2 of this thread you stated that when you did the <RETURN> boot trick with CP/M without the keyboard/cable connected and then connected the keyboard/cable you got a load of lower case 't's displayed. Is this still the case? This would indicate a problem with D4 (check the key matrix) but this is connected to UE12 pins 16 (input) and 15 (output) and nowhere near pins 7 or 8. This is inconsistent.
Did you perform the test I asked back in post 3? If there is a faulty UE12 (or associated logic) this *** SHOULD *** show up with this test.
I agree that if you have performed the test with UE12 pins 7 and 8 three times with the same result then it is valid. However, in my experience, measuring a datas bus line with a voltmeter (which is effectively what UE12 pin 7 is) shouldn't cause the problem you are stating. Otherwise, I am stumped - unless we have a problem with the output of UE12 pin 7 - and this should show up with the test asked for in post 3 again.
UE12 pin 7 hosts keys 7 O U J M and L.
UE12 pin 8 hosts keys 2 left-cursor W S X down-cursor.
We may (of course) be chasing multiple faults - each with their own symptoms. This is a possibility.
The 'damage' (if that is what has occurred) could have happened with the unpolarised cables you used - and then we have subsequently observed that symptom. The original problem could have been a faulty keyboard 'T' switch?
I would guess that replacing the main board should work. But there are still no guarantees and (until you know for sure) this could be an expensive way to find out it doesn't cure your problem.
I am off to bed...
I am off to bed...
