1ST1
I love the M28 and M280, but it is a strange AT, using XT keyboard layout... But if M28 also uses that chipset, why you wrote new tool for M19 for switichng 4.77 to 8 Mhz? It should be there already for M28...
Why you wrote new tool for M19 for switichng 4.77 to 8 Mhz? It should be there already for M28...
Olivetti was 2nd biggest producer of PC in the world at M24 times. But that's not all, it was popular in Europe, and as AT&T 6300 and Xerox 6060 popular in the US. I have german computer price lists of that era, and the cost of M24 was mostly equal as IBM 5150, 5160. Same price for better machine. Those who bought IBM instead bougt it only because of the smart IBM men in blue suit with tie.That tells me Olivetti video system was more in market range of IBM video systems than any other of these 'alternate' cards like Plantronics which remained a niche.
But then M240 was better, more compatible, specially on low level floppy operations and easy upgradeable graphics.It's not only about the specs of the video system but the machine running it, M24 in my opinion is the best personal computer of the first half of 80s. No contest.
Also GEM looks very nice on Go 329.Again, Windows brought Display Enhancement Board drivers for M24 in the years when it was known Olivetti isn't continuing with it, as they already moved to EGA. This expensive piece of hardware was not owned by many, its architecture was on the path to obsolesence, yet Microsoft made sure it was 100% supported.
Copied a 361723 bytes file using the copy command, not xcopy.@Jan de Lange @choas75 Guys you run floppy drives and/or greaseweasel on M19? Could you, when it is convenient, test the floppy I/O speed while in normal and turbo mode?
Src/Dst | 4.77Mhz | 7.16Mhz |
C/B | 29.22s 30.33s 29.33s | 29.05s 29.27s 28.33s |
B/C | 21.27s 21.22s 21.27s | 20.38s 21.27s 21.27s |
C/A | 33.38s 33.38s 33.38s | 32.33s 33.27s 32.22s |
A/C | 21.38s 21.33s 21.33s | 21.16s 20.38s 21.00s |
C/Z | 22.38s 22.05s 22.38s | 15.38s 15.38s 15.38s |
Z/C | 22.33s 23.00s 22.38s | 16.05s 15.27s 15.27s |
Yes, writing to Gotek is even slower than writing to a 5.25" 360kB floppy.Surprising is the very little more speed for gotek versus mechanical floppy.
The result is as expected, because when running at "8" mhz the floppy drives wouldn't rotate faster, so FDC data rate stays the same. Surprising is the very little more speed for gotek versus mechanical floppy.
