Chuck(G)
25k Member
Gparted and Clonezilla have made HD migration for me almost effortless, regardless of the OS being moved.
Isn't the BluePill STM32F103?
I've seen similar effects on the 407 using my own SDCard I/O. But you're probably using SPI mode, where I'm using the builtin SDIO controller. Most of my issues were timing (I was using DMA for I/O) on multi sector writes.
If you don't mind reading C, I can pass you a copy of my SD SPI I/O for the 103.
That was a feature with Win95 = "long file names" described here.
I can remember struggling with this with the first release of Win95 when working on disk forensics tools. It struck me as a kludge back then and still strikes me that way.
I second the recommendation of FatFS - I've used it on a number of projects. Is your goal to use it to host files that are used as block storage? For example, old system reads or writes a block -> microcontroller -> reads or writes block into a file running in a FAT filesystem on sdcard.
