Hello! I'm Mike. Have a PC-XT I acquired back in the 90's, been mostly in storage since then, last fired it up 10 or more years ago I think. Anyway, thought I'd play with it again. Well, this is what I see on the 5151 monitor. Clearly no data is getting to the screen for some reason. The machine seems to act right on power-up, after a little over 20 seconds it emits 1 beep, tries the floppy drive, then accesses the hard drive. But nothing ever happens on the screen. I suspect the monitor, just because I figure it might be more sensitive to the shocks of riding out several moves. I have removed and reseated the video card.
As far as repairing the monitor, I'm not any kind of electronics tech, but I can solder, can remove and replace, might be able to find and repair a broken solder joint....
Is it feasible to get the existing card to drive a modern monitor, one with a 15 pin connection?
Grateful for all helpful suggestions.
