Marty
Hi All;
Dave, Thanks for the update information..
"" Do you have any idea what your RAC card revision is Marty (or I suppose the next best thing is the part number on the E89 ROM). E89 (Rev 'H') is supposed to be '23-C02A2' (as is Rev. 'F'). ""
Mine show '23-C02A2' just like Yours.. I think my Rev on the Card is (I think) REV 'C' .. As mine says ""M8103C P2, but it could be 'P' ..
What is written on the Back of Your Card ??
For the Most part my Proms are not TI, I have three TI, three National, and the rest that I have no idea of who they were made by, It kind of looks like 'IIIIIL' ..
Also Proms E99 and E100 are both Good.. Now to the Next set..
"" I think you may have come across a microcode 'fix' here! "" OK ..
At Location '056, (once we get everything read) I think we should compare what the Micro-code does in each of the scenarios and make a flow chart for each one and try to see what changed between the two Versions..
Also Proms E105 and E107 are also Good.. Now to the Next set..
This also means that If the rest of the Proms are OK, that there is something else wrong with my RAC Board..
E106 and E108 are Good.. Now to the Next set..
I found a Bad Prom, I saw it change right in front of my Eyes from the Correct Code to the Incorrect Code.. E115 is Bad and will need to be replaced.. The first four Addresses are no good.. And it's a TI Prom !!
E114 is Good, I checked it.. Next is the Last two proms..
E113 and E116 are Good to go..
Dave, Your Hex file on Address '027 You have C8008 and it should be C9808, just in case, there is any confusion..
So the only really Bad Prom is E115..
I was able to verify most of the E115, with cool spray, except for the first 16 addresses of '200 to '217 which has a problem that no amount of cool spray will seem to correct..
THANK YOU Marty
THANK YOU Marty
