People still collect plotters?
Unknown_K
Ohio/USA
Was looking at ebay a few days ago and noticed a Roland X-Y Plotter DXY-990 went for $250. Do people still use plotters for drawing or are they used for something else?
X-Y plotters are still very nice if you want to print designs and don't have an overly large printer (I have one running off a print server) but a lot of the bigger units get repurposed with cutting blades to cut stuff like paper and vinyl.
I have several but my max bid is about half that. However the DXY-990 is a nice plotter, says came with original box, so collectable. Pictures seem to have gone, but yes collectible...
Good grief, yes! What else do you use when it comes time to spit out a blueprint?. Note that this HP model will also scan them.
Everybody uses those wide industrial HP inkjet color PRINTERS for prints (well anything larger then a 11x17 laser can do). Kind of cool how they cut the rolled paper to size as needed.
Speaking of blueprints, I had to run an ammonia based blueprint machine a few times at a company back in the 90's when the operator wasn't around. Such a simple way of making copies, hope somebody made a mint off that patent back in the day.
Some of the old HP (letter sized paper) plotters also rolled the paper. I recall reading an article in HP Journal (remember that?) about how the little rollers that propelled the paper had a very proprietary surface.
There was also a class of large-scale plotters where the plotting head rolled around like a little robot.
And, of course, the ones that used the electrographic paper (aluminized surface over carbon).
And then there's the Etch-a-Sketch.
