But you're treading on thin ice there; I see that even a post in the "completely off-topic rants" section was criticized for not being about vintage computers (among other things) so a sauerkraut recipe in the Commodore section is really asking for it... ;-)
As for building an EPROMmer, I recently read an article about an inexpensive and easy-to-programm microcontroller board called Arduino (http://arduino.cc/) in the German c't magazine. I wonder if this was a suitable device for controlling the burning process, or if there are even Arduino-based EPROMmer designs already out there.
BTW, I hereby grant permission to publish my private letter to Dave on the internet ;-) I must, hoever, add an erratum: Haribo's founder's name was *Hans*, not Harald Riegel.
Ah, forgot to mention that it's unresponsive. But even if it weren't, it's got BASIC 1 ROMs, so no monitor. The chips are OK, so if it's that kind of problem it'd have to be the buffers (or the sockets of course, but it's 100% consistent and repeatable while bad sockets are usually intermittent).This is a tricky one. You might try to power up with ground on pin 5 of the user port. This should get to the monitor. If so, check for the contents of RAM using the .M command (.M 1000 1020), and see it you can edit memory with FFFF and 0000 patterns and see if there are stuck bits.
--OK, I was thinking of my 8032 where no RAM is socketed.
If all RAM has been replaced, you should make sure the -5V bias for the RAM is OK assuming they are the 4116 dynamic chips. Is the kernal ROM on sockets also?
I've been beta testing a little adapter that Jim Brain is going to sell that replaces a 6540 ROM with a standard 2716 and with a few jumpers and a gate I managed to replace the whole set with a single 27128; interestingly it now boots but there are some anomalies in the display that lead me to suspect that the problem is with the memory addressing. I'll check it out tomorrow and maybe replace the RAM with a 6264 while I'm at it.
Yeah, distracted by other projects and 'real life'. I only dug out the PETs to test Jim's ROM adapter and thought I'd have a quick look at the dead one while I was at it; then some CP/M and Tandy M100 stuff distracted me and the coming winter is making some outstanding 'projects' around the house more urgent.Mike,
Any update? Or did you let yourself get distracted by other projects?
-Dave
