Hi,I would love to test it in my Olivetti Prodest PC-1 (Nec V40, 512 kB RAM) but I doubt that it would fit in the ISA slot at the right side of this keyboard-PC. The ISA slots are a bit deeper in the housing so an ISA card would require to have a bit longer contacts as usual ISA cards.
Here you can see the ISA slot of that neat PC. Olivetti offered an expansion box fitting here in good old times, having 128 kB extra mem, XTA harddisk and one ISA slot.
Question: Can I disable the floppy emulation function of your card, or can it be moved tó alternative FDC adress. On alternative adess it still could be used to load disk images and copy them to real diskettes using some special copy programs which support secondary floppy controler...
I know the Olivetti PC1, I have one (But never tested it yet)
Generally, an ISA Rizer is added to the PC1.
Everything can be enabled and disabled. I also plan to integrate a Floppy copy/Creation menu dirrectly in the BIOS (Simple to do, but my test PC Floppy is not working)
