CPE1704TKS
I just purchased a Polymorphic 8813 that I am looking to restore. However, I do not have a system Diskette for the system. Is anyone here able to make a copy of a system disk for this system?
I found a PS/2 to Parallel adapter on eBay for about $2. Is the Polymorphic keyboard pinout the same as a printer port?
I just realized that it provided the parallel bits, but not the strobe signal. The item is a ps2 adapter for Arduino. Is there any way to produce the strobe signal easily?
What exactly does the ^@ null character do on the Polymorphic, and why can it not be omitted?
Ok, I found it. You made me look it up. It was what is called a Pad character. When sending a CR to a teletype, or other printer that has a platen ( my first printer that was like a typewriter ) and requires a delay for the platen to return, you'd pad the printing with null characters as these were non-printing. I recall now that I had to do this for my printer. I didn't recall what it was but now I remember.
Most printers now days have a busy signal. In those early days, printing was done with a simple serial machine that didn't have any hand shake method. No one was likely to have a Centronix type parallel printer.
Dwight
The convention for Teletypes was CR-LF-RO-RO (RO=127=rubout). Nulls (00) were returned when the tape reader was reading blank leader. Rubout is all holes punched--so called, because one could correct a erroneous character when punching tape by backspacing and hitting rubout, then continuing with input.
How many people remember manually preparing paper tape for transmission? Did this go out of style when the last Telex machine was scrapped?
