Class X and Y line-filter capacitors tend to dry out on older machines, and they fail spectacularly. I'd replace them right away regardless of whether you smell the magic smoke or not, because it's not a matter of IF, only when.
It's not a matter of drying out; often it's a case of moisture intrusion. Film caps (X and Y-rated safety caps are examples of these) have a rather more complex failure mechanism. But the failure rate exhibits the typical "bathtub" curve.
https://arxiv.org/pdf/1607.01540.pdf
I think that it's interesting that the audiophile community seems to like the Rifa non-safety caps and don't seem to have a problem with them.
1) Class X and Y line-filter capacitors tend to dry out on older machines, and they fail spectacularly. I'd replace them right away regardless of whether you smell the magic smoke or not, because it's not a matter of IF, only when.
2)I'm not too fond of tantalums in new designs, just because when they go, they fail short-circuit and often leave skid stains. Obviously, people like them because they're more compact, and when refurbishing an old machine, I'd still replace like with like, just to keep it true to the old design.
