Bo Zimmerman lists the known Datassette models:
http://zimmers.net/cbmpics/dtapes.html
The discussed model is uncommon for sure, but "very few" probably was a personal reflection by your co-worker. My unit is stamped DATASSETTE rather than C2N CASSETTE like yours is. The S/N is 181548 and on the inside, the circuit board is dated 1979. I can't read the S/N on your picture, but assuming Commodore numbered units sequentially (which is a wild assumption), at least some 180,000 units would've been made since the PET era.
Apart from the missing recording LED, the 1530/31 series had a pre-drilled hole above one of the screws for the R/W head. Thus it was possible (but not recommended) to slightly adjust the azimuth angle using a small screwdriver. Once you start adjusting it, a special alignment program would be required to restore it.
