Realigning 400K floppy Drives
NeXT
Kamloops, BC, Canada
I have a friend who has a drawer full of the Sony 400K drives that are "junk" because they've all had the track 0 photo interrupter tweaked. He says there's nothing you can do after that's been meddled with because there is no utility for the mac to realign a drive and without doing extensive googling it seems correct as I've never come across anything either. Are we both overlooking a utility or tool that people use to realign the heads?
Depending on the drive, I know Sony had some special hardware that connected to the SMC-70 to repair their first SSDD and DSDD drives. I've never seen the software or the hardware outside of a manual.
looking st thst guys listing. thst floply drive has the same adjustment tab (where he uses a flatblade toadjust) as the epson single height 5.25" drives on some of the kaypro computers.
There is a utility for macintoshs that might help, if you have an older 512k/se lying round ...
Sony Disk Interface Test
I realigned mine (in my 512k) without any utilities. I loosened the screw, moved the sensor back just a hair, and it’s been fine ever since. I think any drive could be realigned with enough fiddling.
Never worked on a Macintosh floppy drive, but just screwing around with PC floppy drives, I've found just adjusting things until the drive can scan through all sectors on a known good (never written to) factory mastered disk with no retries, and write a disk that is similarly readable with no retries on a known good drive - is often "good enough".
I am not familiar with any Macintosh tool for just scanning all sectors on a 400k/800k drive, although there should be something out there. Norton Utilities for Macintosh comes to mind, but I seem to recall that doesn't like the early file systems found on 400k disks.
I did the same with my 400k on my Lisa. I spent hours in confusion because I could read a disk from another drive, partially, but not write and have it read. I literally just kept adjusting the head and such until I got lucky and it worked. And it's been fine since. Pure luck I suppose.
