Looks like my computer can hold over 2 MB of ram. Could I do anything with that much ram on a 286?
You can use Windows 3.x, although if you have the original Compaq VDU, you'll only be able to run it with CGA graphics. Software that runs on 286s and uses extended memory is rare.
I haven't bothered with the VDU since I figured out how to switch the video board that came with the new computer into CGA mode. I'm still using the Compaq monochrome monitor, but I could plug a TV into the card and switch it into EGA mode if I so desired.You can use Windows 3.x, although if you have the original Compaq VDU, you'll only be able to run it with CGA graphics. Software that runs on 286s and uses extended memory is rare.
I always had the impression that the 286's role was mostly to run PC or XT software, only faster. Are there any major programs for Win3.1 that'll run on a 286, or would it be a novelty?
Quite a few, assuming that you have access to a repository of older software. Understand that until the Win32S mode became available, all non-standard/real mode programs were written on the 16-bit 286 segmented mode model.
Hrmm... I'll have to try it when I'm through paying for my classes. Would I benefit from installing an 80287 in any way?
