Reference diskette for Memorex Telex 7270 microchannel system (Olivetti P700)
ardent-blue
Folks, someone pinged me, looking for a refdisk for a Memorex Telex 7270.
Sure, buddy, anything else....
BUT after some searching on Al Gore's internet, I found the Olivetti P700 is an OEM...
http://mastodonpc.tripod.com/personal/p701.html
http://mastodonpc.tripod.com/personal/p701-p.html
Where did the intrepid soul with this collection go?
v/r,
god-Emperor of Microchannel
Huh, Olivetti M480-50 is a Model 90
http://mastodonpc.tripod.com/personal/m480-50.html
P.S. Memorex Telex 9290 is actually a Model 90....
http://mastodonpc.tripod.com/personal/9290.html
P.P.S. Olivetti P500 is microchannel
http://mastodonpc.tripod.com/personal/p500.html
P.P.P.S. Olivetti P750 is microchannel..
http://mastodonpc.tripod.com/personal/p750.html
P[SUP]3[/SUP].S. Olivetti P800 is microhannel
http://mastodonpc.tripod.com/personal/p800.html
I know this is an old thread but I need this reference diskette.
Can anyone help???
You could try https://archividigitaliolivetti.archiviostoricolivetti.it/ricerca/ to see it they might have a copy of it in their archive.
But you will likely have to send a couple of blank disks and pay some funds for it.
There is other companies' reference disk for systems with MCA bus, but I don't know what chip set it is using or who's BIOS
firmware this machine has. So, real IBM PS/2 Reference disk may not work. http://ibmfiles.com/ps2disketteimages.htm
If the system has a Phoenix Technologies BIOS Firmware, then if you can find a copy of their MCA setup/diagnostic disk that should do it (, more or less).
Micro Channel architecture was first introduced at the launch of the PS/2 range in 1987,
Tandy Corporation 5000 MC, NCR Corporation's PC division . A small number of other manufacturers, including Apricot, Dell, Research Machines, and Olivetti adopted it, but only for part of their PC range. Any one of their diskettes for a MCA system might work, if the chip set is the same and the BIOS firmware is close to what the setup/configure/diagnostic diskette wants.
The MCA setup/diagnostic disk for the Amstrad X386 with MCA bus might also work, other than the video and other incompatible hardware.
Memorex Telex 7270 Olivetti P700-100 is an unknown model clone of an IBM ps/2 model?
The old Intel MCA chipset utilities disk might work, if it is using an Intel MCA bus chipset.
Could be NCR Microelectronics MCA chipset compatible. (But I doubt this is one that used it)
Sorry I can't be of much help with locating the disk. But may be another reader of this message can be.
To use any MCA cards, you will need their ADF files in order to configure/re-configure them.
The Memorex Telex 7270 or Olivetti P700-100 are a rebadged Mitac MPS3000F with different manufacture faceplates.
Details of this mother board chip set can be found at https://ardent-tool.com/Mitac/MPS3000F.html
Built around the Intel 82311 Micro Channel compatible chipset. Chips 82C451 VGA ctrl. U89 ADV471KP50 RAMDAC
Based on Phoenix 80386 Advanced ROM BIOS ver. 1.02.00. Olivetti P700-100: Planar ID FEFF, machine model/submodel F8/0D.
Related link https://ardent-tool.com/Memorex/ see Model 7270 information.
The reference disk for the Tandy 5000 MC computer can be found at https://ardent-tool.com/Tandy/5000MC.html (may not be fully/or compatible with the Mitac MPS3000f system).
Can anyone help???
Seen message from Dec 18, 2022, while I was searching for other stuff.
https://ardent-tool.com/utils/#SIT has some Utilities and drivers, System Information tools that you can download for free.
As far as a compatible Mitac MPS3000F ref/setup disk I have noted about it in the other message I have already posted.
You might have to do some online digging to find a compatible ref/setup disk if nobody else post any other help.
Can anyone help???
You could try one of the following (,setup and diagnostic disk)
Files are @ https://ardent-tool.com/Olivetti/
p500ud18.exe (IMA) P500 Setup and Diagnostics
p750u101.exe (IMA) P750 Setup and Diagnostics
p800u101.exe (IMA) P800 Setup and Diagnostics
(For back ground information,) See message from Dec 18, 2022, while I was searching for other stuff, I cane across the request.
Hopefully one or a combination of these other disk images work for you.
