It's even worse than that. From within RMENU you cannot run any program, that uses the IP protocol itself. This is due to the combination of the WATTCP library linked to the program with the packet driver which allows only one program to register for a given protocol at a time.Like if you have RMenu running, you can't access anything, which runs on port 23.
I'm still confused:
You are using Telnet to get to Rmenu on a DOS machine. Once at Rmenu you are then dropping to a command prompt/shell and trying to telnet to another machine from that DOS prompt?
The probably easiest way to do the kind of "telnet hopping" you apparently want to do would be to install a second network card and a second packet driver.
Well, DOS is not UNIX! While programs like RMENU (and others) try their best to "look like" a real TELNET server, their possibilities to mimic such systems are limited.I thought I could solve it, like with a Linux device.
I still dont fully understand the problem you had as i don't exactly know what you were trying. Assuming you just wanted to play around with the (unmodified) demonstration configuration that comes with the package and assuming that you chose item "6" of the menu which this configuration displays, then your problem could simply have been, that you were a bit to unpatient. The operating mode behind that menu item is indeed somewhat slow so you should avoid typing ahead of the character echo. Try to obey that rule and see what happens.Nevertheless: What is causing the issue with cutting of an end of a command?
norbi@XXXXXX:~$ telnet Hal-9000
Trying XXX.XXX.XXX.XXX...
Connected to Hal-9000.XXXXXX.
Escape character is '^]'.
C:\>rmenu
RMENU V1.7 listening as XXX.XXX.XXX.XXX on port 23
Please enter selection, use '?' to show menu>
C:\>rmenu
FreeCom version 0.84-pre2 XMS_Swap [Aug 28 2006 00:29:00]
C:\>
C:\>cls
C:\>ssh2dos norbert79@sshhosting.net [I]{At this point I press the [B]Enter[/B] button}[/I]
[I]{screen clears}[/I]
C:\>ssh2dos norbert
As i have no personal experience with ssh2dos i have some more questions first:Code:C:\>ssh2dos norbert79@sshhosting.net [I]{At this point I press the [B]Enter[/B] button}[/I] [I]{screen clears}[/I] C:\>ssh2dos norbert
fake_int9:
cmp cs:[int9_flag], 1
je skip_int9
db 0EAh ;far jump to seg:off
old_int9_ptr dw 0
old_int9_seg dw 0
skip_int9:
iret
- Is that "{screen clears}' part of the normal behaviour of ssh2dos?"
- Is that uncomplete "ssh2dos norbert" part of the normal prompt of that program?
If so, i assume that even though you inserted a second ethernet card into you computer (didn't you?) SSH2DOS keeps on using the same ethernet card / packet driver as RMENU. In other words SSH2DOS still takes over RMENU's network link cutting that later one off from the connection.
An alternative could be to use Mike Brutmans TELNET client in place of SSH2DOS. WATTCP and mTCP should happily coexist and mTCP can (and has to) be assigned a packet driver interrupt explicitly.
In that case it is even more likely that it's the SSH2DOS taking over the line and kicking RMENU out of the boat. And of course you have WATTCP! It's directly linked into RMENU and probably into SSH2DOS as well. And even if not, they both try to use the same packet driver at the same time, but packet drivers aren't multitasking, like DOS as a whole.At this point I haven't used any second Ethernet card, because that would need additional cabling, for which I don't have the possibility yet. So the configuration was still the same: Bare 486 (5x86 - 133 Mhz CPU, 40 MB RAM, Realtek 8139 Ethernet card running Realtek packet driver, 1 Ethernet cable, DHCP through FreeDOS, working perfectly, no WATTCP afaik).
