Surely two lamps above opposite corners of a cuboid piece would give you the same coverage(?)
While I understand the physics, I'm not sure completely even exposure is all that critical. Folk seem to have been getting good results with a single UV lamp above the piece(s) being treated. YMMV and all that ;-)Well, two things.
First of all, a surface at 45 degrees to the UV source is only going to get one half of the strength as a surface at right angles to the UV source. (Think of the strength of the sun at a lower angle in Winter).
Second, the parts that are farthest away from the UV source will get less exposure. Remember the "square of the distance" rule.
Looks like I'm going to have to deal with "one surface at a time" and go through five treatments per piece.
Does any of the swedes here have a shopping list for swedish equivalents of the retr0bright ingredients? I have no idea what Xanthan Gum is, or Oxy laundry booster for that matter. My laundry skills go about as far as using a different powder for color/white laundry and I usually throw in some softener as well...
Mixed up my first batch this evening just to give it a quick go. I think I may have overdone it with the Xanthan gum though, as the stuff ended up looking like a big bowl of thick, white snot. I'll be adding it more gradually next time...
Anyway, I spread it out on the old C64 case I had waiting for it and it's sunning itself away on top of the washing machine as we speak. I have a half-metre UV tube hanging above the cling-film-covered de-yellowing chambers, which are glowing like something out of a sci-fi movie. I'll rinse the lot down before turning in for the night and see if anything's happened...
Certainly not seen anything quite like it before. Now that the oxy's been in there a while, the snot's transformed into whipped cream. Don't fancy tasting it though!Yup, XG is good stuff, isn't it? You don't need much! :D
I don't see an awful lot of glowing in the goo itself, but the plastic tubs look like some kind of alien hatchery. There must be something in there that reacts the same way. Cool effect though, yeah ;-)The glowing you are seeing is partly due to UV optical brighteners that the manufacturers add to the Oxy, so that your whites look super bright (and your shirts glow at the disco). it looks like really mad science though, eh?
Thanks!OK....
Xanthan Gum is a food thickener that can be found in some supermarkets and health food shops; it is sold as a replacement for gluten in bread for people with gluten intolerance or coliac disease. You can also get it via Ebay.
Oxy Laundry booster; This goes under loads of names. the most popular seem to be Oxi-Clean and Vanish. It's usually sold in 1/2 kilo pots to be used as one scoop to your laundry - it's in the laundry aisle (meh) at the supermarket.
Glycerine (or Glycerol - same thing) can be obtained from a pharmacy, usually in 100ml bottles.
I presume you have read the Wiki article, which has pictures of the ingredients...??
Yeah, I was following those very instructions. I was however making a small test batch as a pint is quite a lot, and I didn't have a jar at hand to store the non-activated gel. So there was a bit of guestimation involved when it came to the quantities and I reckon I have a non-standard table spoon ;-) I'm using one of those hand-held blenders, so I think next time I'll just sprinkle the stuff in whilst mixing so I can keep an eye on the consistency.@ Cosam: there's some good instructions in the Wiki about just how to mix the stuff. If you are talking about having overdone it with the Xanthan Gum, and adding it more gradually, I think you may be trying to reinvent the wheel. We've already been through that stuff. You could save yourself the pain and expense.
The stuff I applied didn't seem to foam at all but the leftover paste in the mixing pot did get significantly larger.The stuff may get nice and foamy like whipped cream, but I don't think I've ever seen my XG mix get like that. Early mixes did get foamy, but not the newer recipe.
After loads of trials, I found that one UV lamp just didn't cut it.
I've been using four spaced about 4" apart, and doing one side of a piece at a time.
Here's my setup:
I did have more luck with the bezel on the front of one of my PDP-11s though:
Is there anything special about that last smidgen of yellow that needs more effort or is this just as good as it's going to get?
