My 5160 PSU fan sounds A lot! thinking about to replace it, does it have standard measure? if so, what measure does it have? and what type of connector? maybe it is soldered? If i could replace the fan i would reduce the noise like 50%.
Does the fan rattle or sqeal? If not, you're best off leaving things as they are. The original US 5150 PSU fans were very loud--they were AC-operated. The 5160 fans were somewhat better, but now you understand the desire to take the noisy box and put it on the floor. The fan in your unit is most likely a 12VDC fan, but remember that it provides the only air movement in a very tightl box--so if you do replace it, do not skimp on the CFM rating.
I oiled and cleaned the PSU and noticed when i held the really heavy fan in my hand that the fan do rattle, but i cant tell if it is much or less or normal, but i think the bearings is a bit worn.
And the fan seams to operate between 208-230V, so replacing it will be a bit hard!?
No, replacing the fan is very easy and straight forward. I had to do a fan swap on my 5150 PSU a short while ago. When removing the van, leave enough of the original leads so that you can use crimp-on joints. I used plain metal ones and covered the exposed metal with heat shrink tubing. Now the power supply is as quiet as a mouse.
Do yourself a favor and do as fatwizard suggest and clean the fan blades of any accumulated dirt and dust. You will be glad you did.
Etri is still very much in business and the replacements for the 126LF-2181 are available, even in the 220V model.
For example, here.
However, AC fans are generally much noisier than brushless DC ones, so if you wanted to, you could replace yours with any 30 CFM 80mm 12VDC BLDC fan and run it from the +12 output of the supply.
Yeah i could connect it to a +12V output, but most fans seams to have 3 or 4 pin connector, and the IBM fas has 2 pin connector, is it easy to work around that?
2 wire fans are available, Extra wires are probably for speed control / sensing. Case cooling fans work OK, Get a decent one and it should last for years and are much quieter.
Stop right there! The connector that the original fan connects to in your power supply carries 220V! Don't even think about connecting a 12VDC fan to that! You'll have a marvelous display of smoke and possibly a fire.
If you're going to use a modern 12V fan, you'll have to solder leads to the PSU printed circuit board to get the needed 12VDC. 3 or 4 wire fans don't matter--the extras are used for temperature sensing, stall indication and/or speed control. You need only concern yourself with two of the wires (usually red and black, but not always).
It's okay--your comment about using the connector alarmed me.
Yes, you can solder to the same spot that the cables use on the printed circuit board.
The important number is how many CFM (cubic feet per minute; 1 cubic foot = about 28 L) of air the fan can move. Your AC fan spins at 2750 RPM and provides 27 CFM airflow according to the datasheet.
One of the reasons that the fan spins so fast is that, compared to a brushless DC fan, there's very little room for the fan blades! So the fan must be spun faster to provide the airflow--and is more noisy.
its CFM s at 26 if i use U.L.N.A adapter, i guess 1 CFM dont matter?
Actually it's about 15 CFM, You need to convert 26 Cubic meter per hour (m³/h) to Cubic feet per minute (CFM)
Airflow 53 m³/h - ( 31.19 CFM )
Airflow with L.N.A. 39 m³/h - ( 22.95 CFM )
Airflow with U.L.N.A. 26 m³/h - ( 15.30 CFM )
Looks like a Nice fan for your purpose, though i'd probably not use the adapters.
